Propertie to a whole document
Gwendal_Fernet
Member Posts: 7 ✭
Hello,
I was wondering if there is a way to add some properties to all the parts from a document or just a tab, for example the project name? For now I have to add a project for each parts from the same document. As the same when we use the automatic part numbering is there a way to do it for all the part in one time?
This would be usefull, considering all my part from a document are always used to a same project.
Ok I found the solution in the Onshape Videos, just had to select multiple parts and then edit theirs properties. Sorry about this post
Thanks
Thanks
