Ability to set custom color configurations
Steven479
Member Posts: 3 EDU
Hello, I was wondering if it was possible to set a custom configuration for a generated part's color.
Currently I am using this featurescript https://cad.onshape.com/documents/a1c694da929cd0c00da57f1d/w/affc3a805df9b0c08ec7af3c/e/641eb1448fe7d5609b74ae7e
and have a configuration setup in the screenshot attached below.
The only limitation to this feature script is that it doesn't utilize a color panel but raw rgb values, which makes it hard to know
@Steven479
Maybe this will interest you, if you go down to the configured part properties section, there are instructions on how to configure the color of a part directly.:
https://cad.onshape.com/help/Content/configurations.htm
https://cad.onshape.com/documents/79050f17111734a73fc658bf/w/a832379678e66607d88eb634/e/8b90be25e730d78bafd27f66
Jake Rosenfeld - Modeling Team0 -
I know about this feature, however I want to be able to set any color while I insert the part. That is, there is no fixed amount of colors I can select.Jake_Rosenfeld said:@Steven479
In addition, using the configured part properties changes for every possible configuration I have, which is an issue. If I have a 53 mm standoff configured to blue,0
