Join two sketches
fran_martinez
fran_martinez Member Posts: 2 ✭
Hi,
First of all, thanks for your help.
I want to connect two sketck that are not in the same plane along a curved surface, but I do not know how to do it.
This is what I have now, and  I want to create a column to connect the two pieces.
Thanks
  • bruce_williams
    you should be able to use Loft; either solid between the faces or surfaces on the 4 curves.
    www.accuratepattern.com
