Drawing reference field to approvers in multi-tier release workflow
Ivan_Deetlefs
Ivan_Deetlefs Member Posts: 23 ✭✭
edited May 2020 in Community Support
As an example, if you have a multi-tier workflow that consists of Engineering approval and QA approval, respectively. Is it possible to add independent drawing references that reference the respective approvers and dates of approval?
