<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
Why do I lose other dimensioning options when changing base dimension value in drawing
jason_atwood316
jason_atwood316 Member Posts: 5 ✭✭
I am dimensioning a drawing. If I use the 'part value' then I have options to set other units, GDT, etc.
However if I change the dimension value resolution (in my example .714 -> .7140) then I lose all other options (they are all greyed out)
(FWIW I'm using the web app on Firefox)
    You should set the DP using the drop down to the right of the value. If you manually edit the value it is assuming you are overriding the value and it will set it as not to scale.
