mod to model
tony_brown
Member Posts: 3 ✭
Hi to anyone that can help. I have drawn a 34mm diameter tube with a 6mm wall section inside a 40mm square box section with a 3mm wall, this is a welded assembly, HOW do i create a M10 tapped hole in the side of the box section and continuing thro the 6mm circular tube wall. Ive tried the extrude and hole commands etc and have got absolutely know where. Can any one help. New to this so be polite and patient and forgive my ignorance.
Hi to anyone that can help. I have drawn a 34mm diameter tube with a 6mm wall section inside a 40mm square box section with a 3mm wall, this is a welded assembly, HOW do i create a M10 tapped hole in the side of the box section and continuing thro the 6mm circular tube wall. Ive tried the extrude and hole commands etc and have got absolutely know where. Can any one help. New to this so be polite and patient and forgive my ignorance.0
I replied to your other post "Mod to Model"
https://cad.onshape.com/documents/6b004b132db34115a7f94e64/w/7cf75cf4174e45f588f1cf13/e/137627e227714d5ea9767d4f
On extruding hole , blind 50mm , remove and merge with all.
Good to see you giving OS a try.0 -
Tapped holes are at present only possible by explicitly modelling the helical thread (usually overkill) or by making a plain hole the size of a tapping drill, and attaching a comment to remind you that it's threaded, or by making such a (plain) hole in a dedicated feature and renaming the feature "Tap M10"0
Hi @tony_brown if you need for some reason to model the thread here is a video on how to do it :
https://www.onshape.com/cad-blog/tech-tip-creating-a-thread
Otherwise I`ll follow @andrew_troup `s advice and make a commentNicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions0 -
Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com0
Thanks to all, really appreciate your time.0
Tried that Pete, think its because I didnt select the inner tube aswellpeter_hall said:https://cad.onshape.com/documents/6b004b132db34115a7f94e64/w/7cf75cf4174e45f588f1cf13/e/137627e227714d5ea9767d4f
Thanks
Tone0
