Laser Joint FS cutouts penetrate both walls of tube?
DGF65
Member Posts: 3 PRO
I have successfully created pins and cutouts on tube joints, however i cant find a way to prevent the cutouts from extending right through the far wall of the second tube.
See example https://cad.onshape.com/documents/7b1fcf924bc3bd3b89b96777/w/702e3f28adb5dedf3c2d04c3/e/bc9a81099715333be1df8ed5
Am i overlooking something?
I originally posted this in the community support discussion.
When i look at the featurescript, the code executing the tab cut out as Through All.
https://cad.onshape.com/documents/578830e4e4b0e65410f9c34e/v/75269c4a1a5ece98be1e2b6f/e/dfd5effddfd7f2ecce4b0246
Line 539 it creates extrude.
Line 546 it executes the boolean subtraction.
It must be developed to only be used on sheet metal parts.0
