Using a scanned drawing image to help me produce a design in Onshape
ivan_paynter
Member Posts: 1 ✭
I have a drawing which has a plan view layout which I would like to use to help me produce a design arrangement in Onshape. In the past when using a 2D package such as AutoCAD I would have scanned the drawing, inserted the scanned image and then scaled to the correct size. I would then have created my design in AutoCAD using the scanned image as a reference. I am very new to Onshape so would appreciate some very easy to understand guidance as to how best approach this task. Thank you.
Inside of a part studio, you can create a sketch and then insert an image into that sketch. Just like your current process, the first dimension will scale the sketch and image appropriately for you to use as a proper reference: https://cad.onshape.com/help/Content/sketch-image.htm0
