Dimension properties?
Mark_50
Member Posts: 6 ✭✭
I do not seem to be able to get the dimension properties box to appear?
I tried following the directions, but all i get is the icon to drag dimensions around. Anyone tell me the trick?
mark
mark
Hi @mark_50 when you mention the Dimension property box are you referring to the menu where you change the workspace units ?
Because otherwise there is no dimension property box, when on a sketch you just click the dimension feature and dimension the sketch as required
If I misunderstood your question please my apologies.
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions1 -
Thank you for the reply.
Actually i was looking to set a default decimal place, like two , three , four places after the decimal.
i saw thisDimension properties dialog https://cad.onshape.com/help/#drawings-dimensions.htm?TocPath=Drawings|_____5
I now realize that may be referring to drawings and not models. So i tried to create a drawing based on the info on the page i refferenced but I do not get the option to create a drawing?
mark
