Crop view is changing part color
Barry_van_Wijk
Member Posts: 46 PRO
normal shaded view where the part is selected as green. And the thread faces as white
When i using crop view, the white surface is overruled and turned into green.
How can i prevent this?
@Barry_van_Wijk it sounds like there may be an issue with the shaded view here. I recommend you contact support so we can further diagnose the issue (https://cad.onshape.com/help/Content/contactus_And.htm?Highlight=contact%20support). Sharing your document with support through the Share dialog will also help the investigation.0
