Using API, onshape_client and OAuth
Hello,
How do you properly generate a token for authorization?
When I create a client and try to read an access token, the access_token variable returns blank
Code;
Terminal;
Thank you!
Code;
# modules from onshape_client import OnshapeElement, Client # variables config_filename = '.onshape_client_config.yaml' did = '4106f8fea9cf4607edeba1db' wid = 'c11cf0ae6ab5e6297d09562d' eid = '3340d6f3b50b6e32e22d9a3b' # do things client = Client( config_filename )<br>
Terminal;
>>> client.configuration.access_token ''
Thank you!
