Hi, How do I select the bottom inside edge to fillet on Exercise: Coffee Cup
MJCJ
Member Posts: 10 ✭
I am unable to select a bottom inside edge to fillet (slide 17/20) after using the revolve remove tools on this exercise. I know that it will be something that I have not done correctly but I have redrawn several time with the same result. I want to move on but want to resolve this.
https://cad.onshape.com/documents/eb7f563e622b07959e64300c/w/0785910482970f2f28e96aaf/e/39772bf552e05c448a84fde7
Hi MJCJ,
Another option would be to use the `Select Other` command which will allow you to select through faces
https://cad.onshape.com/help/Content/select-other.htm
While you scroll through the other possible selections, they will highlight indicating what they are.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
Thank you Bruce. Yes I worked it out just after posting my question. I must have re drawn the item four times thinking that I had done something wrong. I was trying to select an inside edge from the outside, I just thought that I should try looking into the cup from top view and there it was! All part of the learning process I suppose.0
Hi MJCJ,
While you scroll through the other possible selections, they will highlight indicating what they are.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5 -
Hi Jake, Thank you for this. I will have a practice with that tomorrow. I got the 'Select Other' menu up on my exercise and that looks a good one to remember. All this new learning, I'm really enjoying it.0
