How do I add vertices for a variable fillet?
ron_moreland
Member Posts: 99 ✭✭✭
I want to use variable fillet. The only vertices available to set fillet values are the end point of the fillet path. Can I add more point to the path?
Thanks for sharing @ron_moreland. You can split the face of the part or surface to add additional vertices.
Before Split
After Split
Hope this helps! Here is a link to the split feature documentation.
That worked, thanks!
