dimensions arent working
Hello All,
Is it just me or are dimensions not working.  For example, I make a line.  I use the dimension tool to change the length for 30 mm to 80 mm. I press enter and the value does not change.  I have done this 100 times before, did I click something that is fixing the values.  I have tried it on two different part studios.
Thank you
