Sheet metal flanges - Error & Non-Error with same feature sequence
Isoworks
Member Posts: 22 PRO
Hello,
I was hoping I could find some clarification to the issue that I am having. I have tried every workaround I could come up with.
Here is a link to the model.
https://cad.onshape.com/documents/da3a70869b47f3999450acf7/w/7171c9ada02d83d0f0213349/e/0106c97127bcc24bdc584805
The issue is that I would like to create flanges on the inside of a rectangular opening. The flanges are perpendicular to each other.
In the successful implementation I was able to create a relief cut which allowed the creation of perpendicular flange without pattern overlap. See picture below.
In the unsuccessful implementation of this relief cut I cannot get OnShape to recognize the cut. It will sketch the cut but it will not implement. The closest I can get is to the picture below.
I have even tried creating a 89 degree relief at the end of the flange to allow for the apparent interference.
What is different?
Any assistance would be greatly appreciated.
Regards,
Ian Osborne
What is different?
Regards,
Ian Osborne
@Isoworks, I wasn't able to open the document. Please confirm the url.
@matthew_stacy, my bad. I didn't have this set as public. And I haven't been in the forums for a while. I have changed the model completely so the the exact issue is no longer relevant. However, the issue of cuts being recognized in SheetMetal is still very relevant. I find this very frustrating.0
