How do you draw hidden lines in a sketch?
I don't know how to
  • alnisalnis Member, Developers Posts: 453 EDU
    If you want to draw construction lines that don't contribute to open/closed profiles, you can press "q" on your keyboard or press "Alt + c" and type "construction" to find where it is in your toolbar. You must be in the sketch environment for these to show. If you want to show a previously hidden sketch, click the eye icon to the side of it.
  • T_RathierT_Rathier Member Posts: 47 EDU
    In 3D modeling, the feature sketches will not contain hidden lines. Construction lines can be used as references to create geometry, you can also project existing model edges as references.
Howdy, Stranger!
