how do I make a surface model into a solid model
mark_wills490
Member Posts: 5 ✭✭
I have a surface body and would like to make it solid. I can't seem to find a command for it.
also is there a way to check it for gaps and bad edges?
Check out Enclose to form a solid from bounding surfaces and Thicken to form a uniform thickness solid. The commands will give you an error and highlight the bad areas of the model if there is a problem. Otherwise, if the input surface geometry is good, they will create solid geometry. Hope this helps!Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
@alnis is my personal account. @alnis_ptc is my official PTC account.0
