Auto select
gerhard_jansen
Posts: 7 ✭
Hi. I want to chamfer one edge but auto select selects all edges. How do i turn the auto select off.
I think it actually is, but because the edge you have selected is an arc you're getting a big conical surface that is cutting into the rest of your shape in undesired ways. If you need something different I suggest making a custom path and using a sweep instead.0
uncheck "tangent propagation"1
Still does not do the one edge selected
Fillet can't stop suddenly. If you want a sharp stopping point you can try a swept cut instead.0
Thanks. I used the sweep and works as I intended
Thanks again0
