Can a sketch be flipped over?
Metro
Metro Member Posts: 17 ✭✭
Hello,
I've imported a DXF file into Onshape however, its normal to the top plane but the orientation is that the "bottom" of the sketch is facing up (and the top is facing down).
I'd like to flip it over (like flipping to the other side of a ruler or card)
I know I can use the bottom view but it's a pain when I want to set the view back to isometric.
Thanks for any help.
-M
  • romeograham
    romeograham Member, csevp Posts: 782 PRO
    edited December 2020 Answer ✓
    You can either:
    OR
    • Place the Sketch on a Mate Connector (instead of a Plane). That way you can change the orientation of the Mate Connector, and the imported DXF will go along for the ride. Here's the Help page that might be helpful.
    Let us know if one of these works for you!
  • romeograham
    You can either:
    OR
  • Metro
    Thanks Romeo.
    the Mirror tool did the job.
    Much apprieciated.
    -M
