using "Item label template" to number array items
EvanReese
EvanReese Member, Mentor Posts: 3,082 PRO
I'm trying to name each item in an array parameter. My first thought was to add a hidden Count Parameter and update it with editing logic, which works, but doesn't update with you just click the button to add a new item. It waits till I change something else. Is there another way to do this? I might be overcomplicating it.
  • kevin_o_toole_1
    Can you link the code? Unless I'm misunderstanding, adding a new array item should rerun the editing logic function and allow the hidden parameters to be set.
  • kevin_o_toole_1
  • EvanReese
    Thanks, Kevin. Just knowing that's a reasonable approach made me check my code again and I found I the editing logic for this was inside of a big if() that was giving the odd behavior I'm describing. So editing logic is your recommended solution for this though?
  • kevin_o_toole_1
    Currently array item names depend only on feature parameters, so yes, I think editing logic is the only available solution. Feel free to submit an improvement request to introduce a syntax for including the item number!
  • EvanReese
    Thanks, If it seems to come up more often, I'll do that.
