Qestion about creating a screw joint to control hinge
ky_oisen
Member Posts: 2 ✭
Hello Everyone. I am working on modeling up a barn door tracker for astrophotography and have most things i believe to be assembled how they should be. I have am having trouble with the last part. I'm looking to model a motor turning a threaded rod which would in turn open/ close the hinge portion of my model. I can't seem to figure out how to make it work as a unit, as i add the last mates in other ones freeze.
https://cad.onshape.com/documents/2cb43ca2268e607b5e1f875c/w/3413d2663386efd222fc5dc3/e/fc6dd39383a461a33635b80d
Here is a link to my document. Any advice is appreciated.
When the hinge opens, the nut axis is no longer aligned with the threaded rod. I think the nut will need to be able to rotate around a perpendicular axis "facing out of the screen" for this to work.
▚▞▚▞▚▞▚▞▚1 -
It seems, that the position of the hole is not correct. If you make the plates parallel, you see there is an offset between the spindle and the hole. I would check this first.
Principal Technical Services Engineer, EMEAI0 -
