modifier keys and manipulator change functions
EvanReese
Member, Mentor Posts: 3,100 PRO
is there a way to use modifier keys with a manipulator change function? For example if I have a set of point manipulators I can only pick one at a time, is there a way to pick multiple while holding SHIFT?
It's not currently possible for a points manipulator to specify multiple points simultaneously. Please submit an improvement request if this is functionality you want!0
Thanks, Kevin. I'd love this functionality for the Freeform Spline. The awesome Meta Sculpt feature has a workaround for multiple selections, which I'll have to dig into and see if it can work for me. I would love to be able to make the selection of point manipulators more similar to the selection of other things in Onshape:kevin_o_toole_1 said:It's not currently possible for a points manipulator to specify multiple points simultaneously. Please submit an improvement request if this is functionality you want!- persistant selection
- click whitespace or spacebar to deselect
