Parts modification and assembly
Upon creating an assemby, I realized that i had an interference problem between two parts. How can I change its geometry and see its effect directly in the assembly without creating a brand new assemble
  • tim_hess427
    tim_hess427 Member Posts: 648 ✭✭✭✭
    Onshape makes this pretty easy - Just go back to the part studio and make your changes to the geometry. If the assembly is in the same document, it'll update automatically. If they are in separate documents, make the changes and save a new version for the document. Then, you'll need to right-click on the part name in the assembly and select "update linked document".
