How to move along a curve a certain length?
EvanReese
edited February 2021 in FeatureScript
Say I have a 3D spline (or other curve), how to I find a point along the spline that's 10mm away from the endpoint (as traveled along the spline, not measured in a straight line)?
  • _anton
    _anton Member, Onshape Employees Posts: 554 image
    You can get the curve point from, for instance, evEdgeTangentLine, which uses arc length parameterization by default. To compute the parameter, divide the desired distance by total curve length. Something like this.
  • _anton
  • EvanReese
    perfect! exactly what I was looking for. Thanks.
