Not fully defined geometry with Circular Repetition....??
andrew_banhamandrew_banham Member Posts: 14 EDU
When I am making a sketch that has circular repetition I can not get all of the sketch to be fully defined...
The first part is dimensioned and defined, but anything that is repeated only goes blue?
Thanks
  • MichaelPascoeMichaelPascoe Member Posts: 2,818 PRO
    There is a small square manipulator in the center of the circular pattern, constrain that to something.
    RENDERCAD
  • andrew_banhamandrew_banham Member Posts: 14 EDU
    Still having some BLUE lines
    edited February 2021
    Either that arc radius is not constrained, or it is a bug.
    Ever since one of the larger updates a couple of years ago, constraints will occasionally over constrain or under constrain themselves when they are clearly not over or under constrained. This happens when I am using sketch patterns, or working with lots of sketch entities.
    RENDERCAD
