Problem dxf curves with function loft
filou78450
filou78450 Member Posts: 2 ✭
Hello,
With Onshape, I often work with .dxf files. Once the dxf file is imported into Onshape, the problem I have is the following.
When the curves in the dxf file are made up of several points. I can’t use the « loft » function.
I am obliged to redraw the curve in Onshape with the « Spline » function.
Is there a better method to remedy this problem or is it necessary to intervene upstream on the software that creates the dxf file?
Thank you in advance
Best Regards,
Philippe
