Assembling Sweeps
daniel_irwin183
Member Posts: 4 ✭
I am attempting to use an object in assembly that is just a few sketches sweeped, but it doesn't come up as a solid object? What can I do?
@daniel_irwin183 - Are you sure the sweeps are solid objects? When you create the sweeps, there should be an option to create a "surface" or a solid. It sounds like you want the solid option.
