Aus Beams FS become very slow
rhys_skinner
Member Posts: 17 PRO
I have been using the FS, Australian Beams 2.0 (MBartlett)
Recently the script has become very slow, around 10 seconds per operation.
The FS file is tagged Deprecated.... is it an old version or abandoned?
Any thoughts? thanks
Deprecated simply means it is no longer being actively developed, which doesn't necessarily mean it is no longer functional. If you're suddenly experiencing significant performance problems, I would first check that it is the Beams 2.0 FeatureScript in question using the Show Regeneration Times option in your part studio. It's also possible you are simply doing a performance sapping operation, like importing a beam profile from a poor performance part studio, which could also cause the FeatureScript to become very slow.
If all else fails, updating to the latest version (which appears to be 3.0) may result in better performance and additional features, both of which are probably beneficial.Software Developer at Epic Systems
FRC Design Mentor - Team 1306 BadgerBots1 -
Hi Alex,
When you mentioned a 3.0 version I had to find it.
Took a while to discover the script and finally yes it is much quicker on that version.
Thanks for your comment
Anyone else coming along I have found the Aus beams 3.0 here https://cad.onshape.com/documents/1932527edac323470b3700c5/w/fc73148cab9c8da1ac419ef1/e/95da2845221fb384c15678e80
