How do I make a complex blade bevel
alright so as you can see im trying to model a sword blade, the problem is i would like the blade beveled with the bevels coming to a peak down the center of the blade (where the colors meet) this is something ive tried to figure out for hours now, ive tried drafts, chamfers, sweeps. i just cant seem to figure it out, i want the bevel to go up to/follow that centerline, and bevel each part the same distance downward. the slope (angle) of the bevel would constantly change to keep the depth of the bevel consistent, any way to make this work. is something like this even possible in onshape ? -thank you.
https://forum.onshape.com/discussion/comment/34416#Comment_34416
PS. Let us know if you found your solution to others can stop thinking about it.
