Transforming a movement into a sketch
frank_ring
frank_ring Member Posts: 44 ✭✭
edited May 2021 in Community Support
Hello,
the following task should be solved.
The pin, which describes an ellipse due to the deviation, should be cut out in the plate as slotted hole.
