The wrap feature is not letting me select a target face.
vikram_koli595
vikram_koli595 Member Posts: 31 EDU
The wrap feature isn't letting me select a revolve face. I am trying to wrap a sketch of four circles around a curved surface that was revolved from a sketch. For some reason it doesn't seem to work for some reason. Help would be appreciated.
Here is the link to the project
https://cad.onshape.com/documents/81d2f7f0aa4bb8b799982f93/w/640d51f8ef753957f1a2f4c5/e/2d056ec58a69df83ead1cf71
  • _anton
    _anton Member, Onshape Employees Posts: 548 image
    The Wrap feature currently only supports cylindrical faces. You could split the revolved face using the Split feature and the sketch circles.
  • _anton
  • vikram_koli595
    Ok,  but In my design I need a sort of emboss for my shape. If I try to do the split feature, it won't be the emboss I want, the circles will be distorted when I look at the model from the side but will look like actual surface from the top. I will create a new topic with this issue
