Please Help With Transform Sketch / Redimension
monique_vo
Member Posts: 2 EDU
I am making a chess set on OnShape and accidentally made the piece too small. Is there a way that I can re-dimension it without having to make the piece again?
scale during transform
1 -
@monique_vo - You should be able to open up your sketches and features and just edit the dimensions directly. Is there a reason that isn't working for you?0
