Right angle tube adapter?
jason_traud
jason_traud Member Posts: 15 ✭✭
I'm trying to make a small adapter to convert a one inch pvc pipe to a 2 inch to help clean out the drain on my hvac. I can do this with the simple resolve command when going down a straight pipe, but the corner radius breaks the command. I could probably use the sweep command if the ID was the same on both ends of the tube. But how do I do it with different IDs on both ends?
