Question about mate features in Onshape
dok_man
dok_man Member Posts: 2 EDU
Hello, new to Onshape
I created a simple 3 part model and I connect the mates via revolute
There is a base, arm 1 and arm 2
revolute 1 - the arm 1 will rotate on the base (" pedestal")
revolute 2 - and arm 2 after being connected on arm 1 will rotate around it
after I connected them when starting the revolute 1 movement the arm 2 will stay detached and wont move with arm 1, I thought that because it was connected to arm1 it (arm 2) would also stay attached
  • Alex_Kempen
    Alex_Kempen Member Posts: 258 EDU
    Assuming you've set up everything properly, your model should behave as you expect. I would recommend taking a look at the following video, and trying to apply its recommendations to your own model.
    https://www.onshape.com/en/resource-center/videos/build-your-first-assembly
    If you make your document public and post a link to it, that would also make it easier to troubleshoot what exactly is going wrong.
