2 lines on different planes not connecting
Amir_Lahlou
Amir_Lahlou Member Posts: 2 EDU
edited August 2021 in Community Support
Im trying to make a line on a different plane but use one of the existing lines on another plane for the angle but it won't snap to the other line. Im watching a youtube tutorial step by step and its working for him. Can anyone help?
  • shawn_crocker
    shawn_crocker Member, OS Professional Posts: 1,037 PRO
    Usually indicates the end point of the line the other plane is not perfectly coincident with you current sketch plane
  • robert_scott_jr_
    robert_scott_jr_ Member Posts: 904 ✭✭✭
    Would using the USE command in a sketch on the second plane to capture the line of first sketch on the first plane, onto the second plane be useful in what you are trying to accomplish? - Scotty
  • GWS50
    GWS50 Member Posts: 528 PRO
    Have you tried  the Pierce command
