Print out parts for wood working
manley_gage
manley_gage Member Posts: 4 ✭
Hi there community. I am wondering if anyone knows how to take something I have made and print out the parts on paper for stencilling on wood?
So say I have a complex object and I want to isolate a single panel out of it, then I want to be able to print the shape, in 2d on paper. I would like the print to be dimensionally correct. So that may mean the printer prints out a few pieces of paper that I would have to tape together to get the correct dimensions.
The purpose is so I can take the printed pieces of paper and stick them to a piece of wood and use it to guide me cutting the wood.
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,945 PRO
    edited September 2021
    Here is one way you can do this:
    • Create a drawing (Not a sketch) You can learn about how to create drawings here: https://learn.onshape.com/courses/fundamentals-detailed-drawings
    • Set the sheet size to the paper size you are using
    • Insert the part into your drawing (In this case you may want to choose a larger size that will fit your part 1:1 and tell your printer to print on multiple sheets)
    • Make sure your part view is set to 1:1 scale
    • Export the drawing as a pdf
    • Print the pdf (in your print settings on your computer, make sure scale is turned of
    RENDERCAD
  • manley_gage
    Awesome, that will work well. Thank you!
    Also, sweet Legend of Zelda sword! ;-)
  • MichaelPascoe
    Sure thing.
    Thanks  B)
    RENDERCAD
