Is it possible to change the name of a measure in the configuration table?
René_Sartorio
Posts: 58 PRO
1
As far as I can tell it's not, but it should be. It should also be possible to add text to the dimensions in the sketch. I use that capability a lot in Solidworks to help explain the function of dimensions in layout sketches.
2
2 -
Is there anything to vote up?
This seems to be a relevant improvement request: https://forum.onshape.com/discussion/9771/configuration-column-names
It seems like the best option at the moment is to use variables and then their names show in the configuration table, and you can perform math on them there too: https://forum.onshape.com/discussion/comment/35410/#Comment_35410Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
1
