Icon Incorrect for Part
S1mon
Member Posts: 3,835 PRO
With some PCBAs that I've imported recently, they all have import errors where the PCB itself comes in with one corner fillet which isn't water tight. In the part studio, I delete the face and then fill surface/add and the surface turns into a solid part. However the icon in the instances list of the assembly still shows as a surface.
If I create a brand new assembly and insert the same part I get the correct icon. (this is all in the same document).
It's a minor bug, but definitely repeatable.
