Units problem
mael_simard
mael_simard Member Posts: 2 EDU
Hello,
i worked on a long project but at the drawing moment i saw my units was in centimeters and not in milimeters but the values are good, can we just change the units name and not the values ?
  • Jake_Delano
    Jake_Delano Member, Onshape Employees Posts: 43 image
    You can edit the text in the title block to just say the correct units if you're having the issue that it sounds like you're having
