How do i get the extrude to remove through an imported mesh?
leo_duarte
leo_duarte Member Posts: 2 EDU
edited November 2021 in Community Support
Hello, I'm having trouble getting one of my sketches' extrudes to get through one of my imported meshes, I'm trying to expand/create a 3 inch hole inside of him to use as a
https://cad.onshape.com/documents/4840cbdb78f0c4e0cf47f20d/w/cde7a79e9924d0274d857366/e/4fcd46dc9f82aec5ca5335fe?renderMode=0&uiState=618336f35c61732baaf8f0a9 Linked here, I cant seem to get the extrude to get through the mesh, any help would be appreciated,
    S1mon Member Posts: 4,644 PRO
    There’s a FeatureScript called Boolean Plus which will work with meshes. Ultimately if you need to do a lot of work with meshes you’ll probably want to use other CAD tools. The capabilities in Onshape are limited.
  • Greg_Keosayian
    Greg_Keosayian Member Posts: 26 PRO
    You need to turn the mesh into a solid first then extrude a hole. You're essentially trying to pass a cylindrical solid through a cloud of connected points.
