Different types of revision table
guy_rogel
guy_rogel Member, User Group Leader Posts: 101 PRO
We have different clients asking for different types of revison table. for example with approver and without approver
Currently I think there is just one option that can be changed.
am I missing somthing ?
  • STEG
    STEG Member, User Group Leader Posts: 141 PRO
    Create many revision tables that you place outside the drawing area in your drawing template and then move to the drawing the one you need at drawing creation?
  • Nath_McC
    Nath_McC Member Posts: 136 PRO
    Under the release management area of the settings, you can update the type of revision table. As far as I can see, you can only have one template.
  • guy_rogel
    Thanks Nath_McC
    As you say there is only one option , so once I change it , other drawings will change as well. this is not so good for me.
  • guy_rogel
    Thanks STEG
    this is not a real revision table, it will not update correctly when I release parts. it's a manual version. I would like it to be automated with onshape release process .
