USE command with whole sketch
David_Kirshoff
Member Posts: 7 ✭
I am trying to use the "use" command to project an entire sketch onto a new sketch. Is there a way to do without selecting individual edges/parts of the sketch? Thanks.
Why not derive the sketch ? and click inside a closed shape you can select all line's in 1 click0
solved - open new sketch, click sketch to be projected in the tree, THEN hit "use"0
You can also click and drag to draw a box and select multiple things at once.0
