Can a linear sketch pattern be created by defining specific start and end points?
Is it possible to create a linear pattern that calcuates the appropriate spacing between two points or lines. For example I am drawing out a pencil holder and want to create several holes that are evenly spaced on a rectangle. If I define the diameter, is there a way to select the start and end point and have the linear pattern be created? Does this make sense?
