Assembly Parts Changing Color
noah_alperovitz
EDU
Hi, one day a few parts in my assembly changed to a certain color. For example all of the handles in my assembly turned yellow and all of a certain part turned light blue. I had already assigned a color for these parts in the part studios. This is what the part looked like in a sub assembly:
I clicked on the parts to edit in context and when I did, the part was the correct color that it originally was.
Then I went back to the main Assembly and this problem was fixed for that part, although some other parts still had the same problem. Does anyone know how to solve this problem or know if this is a glitch?
Then I went back to the main Assembly and this problem was fixed for that part, although some other parts still had the same problem. Does anyone know how to solve this problem or know if this is a glitch? 0
Sound like it is a glitch. If you still have the issue reach out to support. I would also try using this add-on to see if you still get the same issue
https://cad.onshape.com/documents/d997b0ffc30f659113b10c00/v/a9e4f209775174dbb9f2b5fa/e/b6db0c9545b9a2df1d7ea546
