Create equal spaced points along a spline
Cobalt_Echo
Member Posts: 31 ✭✭
After a spline in created, is there a way to project or pattern points along a (2D) spline?
I've attached an example (that I did manually on the right spline), but a way to do this effeciently would be awsome.
https://cad.onshape.com/documents/19fe70b9f60fcc2a8750c0cf/w/1b6f2c28ffbce1faacfc4a60/e/3050fd217ea8f0bdd9ea1ba9
There's a Featurescript which can place points along a spline with various parameters. Depending on how you want to measure things, it might work for you.
https://cad.onshape.com/documents/576d1e60c6cb90985345ac37/w/af3cd9578e1e4516cefd7159/e/cda3fea9f8e5c39ee94e206f
1 -
Close, but not quite. This does make points measured along the spline, but I would like the points measure only the x, y, or z axis, and then placed on the spline (like an intersection almost). Not sure if that makes sense.S1mon said:There's a Featurescript which can place points along a spline with various parameters. Depending on how you want to measure things, it might work for you.
I'm having a hard time putting it into words, so I've made a picture. Hopefully this helps.
I understood what you are looking for. Somehow I thought that was an option of that FeatureScript. I suspect that someone with decent FeatureScript experience could use that one as a basis to modify or expand on that one to solve your need. It would be a useful tool in general, especially if patterning was built in or easily done with a feature pattern.
1 -
Cool, I'll post in the Feature Script area and see if I get a hit. Thanks!0
