I cannot recreate the front of this boat
baffour_osei
Member Posts: 2 EDU
No matter how many sketches, extrusions, chamfers, etc. I've done, I cannot seem to recreate the front of this boat. The front of the boat in the image has a skinny mid section that goes from the top edge of the boat to the bottom whereas my CAD model's mid section increases in width as it goes towards the bottom. I've even changed the order of my sketches and extrusions. Please help!
Also, how would I create the ridges on the sides of the boat where you can see its width reduce with each one? Thank you! Here's the link to the doc (https://cad.onshape.com/documents/3dc586bfcb9ee313aae79692/w/8acc8396dbade22bc8a3a2df/e/726c0f81a04e6174b7cf16d8?renderMode=0&uiState=6201e557257b2a4fcad6725d) and I've attached 4 images.
You'll probably want to check out surfacing tools such as loft, projected curve, fill, etc.
I would probably approach this by modeling some cross-sections, then lofting between them, optionally with some projected curves used as guide curves. You may need to break it down into multiple lofts to get the ends to behave how you want.
Here is the training on advanced surfacing: https://learn.onshape.com/learn/learning-path/advanced-part-and-surfacing-design
Here's a model I made recently that makes use of some of those techniques to form its hulls, rudders, and sail:
https://cad.onshape.com/documents/2771b15fa8fed8f3d1898729/w/d70196b6d1ed7f8a61c79df6/e/00d425432f46b7b95fd5ce09
Hope this helps!
Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
@alnis is my personal account. @alnis_ptc is my official PTC account.2
