Upload PDF via Java Client + API
I am currently using the Java Client from Onshape for uploading a PDF as Blob Element.
Endpoint is /api/blobelements/d/did/w/wid
When I upload the PDF with Insomnia (REST Client App like Postman) everything is ok.
But when i upload it with the Java Client code, the PDF is broken in Onshape.
Both tries the same PDF.
Following code is used:
Blob value = new Blob(pdf.getPath());
BlobElementsUploadFileCreateElementResponse uploadResponse = onshape.blobElements()
.uploadFileCreateElement()
.translate(true)
.yAxisIsUp(false)
.flattenAssemblies(false)
.file(value).call(did, w);
AM I doing anything wrong?
