Section cut in render
Hi, is there a way of rendering a part in a section cut which is not hollowed out?
I have a part whish is not hollow but rendering program makes it hollow while in section cut.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 393 image
    Viktor, yes just go to the "Options" (the gear icon) in the Scene graph then in the properties for this you'll find down the bottom of the list a "Caps Enabled" setting. See below:
Howdy, Stranger!
