Part studio disappeared
john_ferrell
Member Posts: 2 EDU
I opened up Onshape after a month or so and the part studio that used to be at the bottom of my documents has disappeared. Can I get it back?
Thanks!
John Ferrell
middle school teacher using an educational version
Thanks!
John Ferrell
Hey @john_ferrell
You can use the Version and History panel to go back to a point in time in your document and restore it, if for example you or a student accidentally deleted the tab you are looking for. You can learn more here :https://cad.onshape.com/help/Content/docmanagement.htm
Also if you have a lot of tabs in your document, I recommend using the Tab Manager instead of the bottom tab bar. It makes it easier to see all of the different tabs and folders. You can learn more here: https://cad.onshape.com/help/Content/elementtabs.htm1
