Merge Scope.
justin_fischli
Member Posts: 2 ✭
How do I select merge scope?
Hi Justin, could you share the document in which you are having trouble with merge scope?In an additive process you should be able to select parts that you want to merge with.You may need to specify certain constraints beyond selection for the additive process to work correctly.For example, an extrusion will need to extend in the correct direction and far enough to meet the part(s) it is intended to merge with in your project.0
